clutch losing pressure
hi all when revvin hard my clutch seems to be dropping to the floor - it comes up after a few seconds but its as if it cant take the high revs? it is sort of flapping down then it returns to norm? help
First, check master cylinder reservoir for fluid level and condition. Second, make sure there are no leaks coming from from the master cylinder by the clutch pedal. Third, gravity bleed the clutch fluid; use a clear hose on the slave bleeder screw so you can see that there are NO air bubbles left in the lines. Forth, try another gravity bleed.
