Clutch job
Clutch job
Hey guys, getting a new clutch installed this week, sadly I can't do any work on my car anymore because of my back so I was getting a shop to do it. My question: is this a pretty straight forward install, as in I shouldn't have any problems once installed unless the parts are faulty? I ask because I have a local that will do the install for 70% less than the shop. And I know the saying you get what you pay for and I usually dont cheap out on my car but it's the difference of almost $400. I read the DIY, it seemed pretty straight forward, just want to know if this is something I should only let a shop take care of
My clutch job was tougher than most because it was the first clutch job on my car, and it's an '03 an had 330,000 miles. Needless to say I encountered some stubborn bolts. I also took care of lots of other maintenance items while I had it torn apart.
Taking off the starter bolt wasn't as hard as I though it would be. The trick is to have a really good light source so you can see, or you can just remove the knock sensor. Most of the time the damage is done when trying to remove the bolt and the tools inadvertently smash into the KS.
Also you may not need then but it's a good idea to get an OEM rear main seal and a new guide sleeve for the release bearing...just in case, because if you do need to replace those things, you're not going to find them at the auto parts store, or the dealership.
It's not a hard job to do in one's garage with the right tools & knowledge, so if the guy has some experience I wouldn't be too concerned about saving yourself some money. But I'd want to either know him personally, or have several people you trust that can vouch for him.
I'm doing ACT PP, OEM disc and bearings. I think I'll just go with the shop then, they are what everyone uses on our local forum and when I go SC I was going to have them do it anyways so it may be good for them to know my car
Originally Posted by afzan' timestamp='1442714879' post='23752184
For your own sake I hope you're not planning on using aftermarket clutch parts
Originally Posted by Princeneo
dropping the trans down is easy, but im having problem installing the trans back, this is an Ap2 , i have used the special alignment and it wont go in.
Once the guide pins are lined up you can pull it in the rest of the way by putting in the tranny mounting bolts and tightening them.
If I can install mine all by myself with just a floor jack, I'm sure you can do it.
Received 1,418 Likes
There is no clocking on the flywheel. And the flywheel doesn't directly engage anything on the trans.
Its just a matter of positioning it. Its always a bitch to do until you get the hang of it.
Or you have doubled up on a dowel pin? Look at the dowel pins that are used to line the trans up. There should be one pin per hole. Sometimes, these fall out and you can attempt to use two pins for one hole.
