Clutch?, on its way out?
OK new one to me, just comming home from the hospital in the car and it was a struggle to get into 6th gear, then 4,5 and 6th.
When i got home and the car was stationary i depressed the clutch pedal and there was a strange noise if i tried to put it in any gear (no crunching or grinding just a noise)
No smells or slipping in any gear and its just suddenly started.
Now its very notchy/stiff changing gears and if i drive along in any gear then press the clutch all the way in and coast like that, there is a noise sort of like a shhhh.
Is it the clutch/bearing?
T.I.A
T.I.A
Could also be a transmission bearing going out too.. Mine's in the shop now for this.
I take it you verified your transmission fluid is full, and your clutch fluid ?
hotchoc4
09-21-2005 10:41 PM
