Clutch Humm
Clutch Humm
Hey guys on my 03, I notice with the clutch out, in neutral I hear a humming, or whining noise every time i let the clutch completely out, after I push it it, its completely silent.
Is this something thats normal?
I've had this on both my OE and ACT clutch.
Not 100% sure what causes it tho. I would assume something in the transmission is making the noise as its only present when the clutch is engaged.
Disengaged is when you push the pedal down (you release the friction disc from the flywheel.)
If you can drive around with your clutch pedal to the floor you have a different problem
Originally Posted by Jasonoff,Apr 17 2007, 09:27 PM
Clutch pedal out means the clutch is engaged. (the friction disc is clamped to the flywheel.)
