Clutch Help
Clutch Help
ok ill try to explain i was driving 5 north and got stock in traffic stop and go for about 1hr and all of a sudden my clutch its slightly harder to press its not normal so i was still going till i got to my destination i finally shut off the engine and waited for about 5 minutes and started the car again and its normal again i said what the f*** anyone can tell me why this happens everytime i get stock in traffic?
thanks
sean
thanks
sean
no i dont think so cause sometime my dad drives my car at night around 7pm while traffic and all of a sudden i get on it its slightly hard to press im not sure if i should bleed the clutch
honda tsb for this. pull the slave off the trans, pop the fork off of its pivot. get a long lil brush, rub a coat of antizeize, or moly grease on the fork faces, and the fork pivot. it will smooth right up. no more sticky, or hard pedal. lates dave
Been there, done that.
what about a clutch pedal that is extremely loose....also its tough as shit to shift gears and reverse almost never goes into gear on the 1st or 2nd try anymore. Slave, and all fluids have been changed, rebled like about 4 times already. There is also a loud clacking sound when decelerating in 1st or 2nd gear and no, its not the clutch buzz as i had that also.
