Clutch help
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Hello everyone I recently just got my s back on the road after 6 months of sitting in the garage and I've noticed my clutch is really soft up top and catches close to the floor and sometime I have to pump the clutch multiple times for Otto go into gear. I tried adjusting the pedal but it didn't seem to help much at all. Anything else I should try? Or any idea what is causing this?
Are you low on clutch fluid? Either way, I bet you have air in the clutch lines.
You should always bleed the clutch thoroughly before adjusting the pedal. There's a DIY somewhere on the site if you're unsure of how to do it.
1 Post
Originally Posted by BenWise04' timestamp='1362507355' post='22381884
I've searched for the DIY and can't seem to find it
Had this issue a few weeks ago...clutch fluid was nasty. Do a bleed and it should cure the issue. Also peak behind the pedal and see if you're getting a leak from the mc. New fluid should fix this leak.
osu s2k
04-16-2004 07:51 PM
