clutch - friction point moved, is now very high
Originally Posted by billman250,May 12 2005, 07:44 PM
You most likely have:
Air in the hyd clutch.
Major play in the pushrod.
I have a MY 01 with only 21k miles , and a very high friction point. After reading some of these threads, I took xviper's advice and changed out the clutch fluid. I didnt' really notice an improvement right after completeing the procedure, but by the end of the day, the friction point was definitely lower. Also, the clutch pedal operates a lot smoother now. Just be careful when filling the fluid reservoire (it fills up very fast!).
Originally Posted by billman250,May 12 2005, 07:39 PM
There is only one correct setting for the clutch rod....zero, or barely noticeable freeplay.
When I say this, I mean play between the end of the rod, and the master cyl piston...you should barely see play in the rod when using light pinky pressure to move the clutch pedal in and out.
Adjusting it in any other way is only masking another problem.
Shortening the rod will decrease the amount of disengagement, and most likely cause disc drag and second gear grinding.
**this may be difficult for some to grasp. When pressing on the clutch with your finger, you will usually feel two different "freeplays". The first is pushrod play, in which 99% should be removed by loosening the 12mm nut, and turning the rod with you fingers to remove the play.
The second is the built in play in the master, which is normal.
Maybe I can put this differently....Even if you adjusted the rod to actually start pushing the master in, say 1/16 inch, there would still be an open fluid passage between the slave down below, and the resovior. There would be no pressure on the T/O bearing.
When the master piston start moving in, the fluid is being pushed into the master res, until the rubber piston crosses the tiny hole and starts building pressure.
I've got about 170 s2k's running around with zero freeplay. They love the clutch action, and the shifting has never been better.
The key of the zero freeplay is: to get max disengagement. Any other setting will reduce this. With the inherent gear grind of the s2k, full disengagement will virtually eliminate it. I've cured quite a few gear grinds in this fashon.
All I can say is try it. I'll bet you will like it...
Hello,
I recently bought a brand new used 2006 s2k with 22k miles. I'm comming from a 2002 wrx which I loved to death, literally, and have been driving stick for 7 years now. I know my clutch isn't slipping, I know the symptoms of a slipping clutch, however it seems like my clutch pedal friction point is abnormally high.
There is also probably about 1" of freeplay in the clutch pedal before it even starts actually engaging the master cylinder.
I just purchased a factory service manual on ebay for 50$, however it wont be arriving for a week or so.
Reading the posts about changing the fluid/bleeding the lines sounds good to me. I also would like to adjust the clutch pedal mechanism to get rid of this freeplay in the pedal. Could anyone provide me with instructions on how to get this done?
I have ATE super blue fluid which I used on my wrx for track events/daily driving etc. and I'm assuming that this would work as well in the S?
I usually do all my own work on my car and have a fair amount of mechanical ability but I don't have a manual for my new S and I've never owned a honda before.
Any help would be greatly appreciated.
and although I'm sure you guys know, I just wanted to say that although I haven't had it for long, the S is in my eyes the "perfect" car. I can't get over how high the potential and ability of this car is.
so where should be your engage point? Im replacing my Clutch Master Cylinder this weekend and I want to know where to adjust it to. Basically hardly any freeplay?
I am not sure, but my engagement point is almost at the top of the throw of the clutch pedal. I dont think it should be this high, and there probably shouldn't be a lot of pedal freeplay.
I read that there is a bolt that is used to adjust the clutch mechanism near the fire wall or something like that.
Not sure how to bleed the thing though. I guess it would be similiar to bleeding brake lines? Don't know if there is a bleeder valve or something like that.
Anyone??
Anyone??
Anyone??
Anyone??
