Clutch freefalls to the floor and does not return!
slalom44,
Do you think this is related to the sticky clutch pedal problem? My clutch pedal feels like its in a bind sometimes while both depressing and releasing it. I've regreased everything under the dash with no releif.
Suggestions?
Suggestions?
[QUOTE]Originally posted by MyBad
[B]slalom44,
[B]slalom44,
xviper, its an 02 and hasn't had any clutch work at all. The car has been autox'd and DE tracked a bit. But I would think it reasonable for the clutch plates to be wore out long before a throwout bearing failure.
there were "hotspots" on the flywheel and clutch plate that would have been a problem if just the clutch plate was replaced.
He said the throw out bearing was dry as a bone... And that my driving habits/style were the likely cause of the problem... I really couldn't argue that. Didn't tell him about all the track events and autox's...
When will they learn to schlopp a bit of grease on that spindle? I even recall seeing a post here that Honda sent out a memo to their service people about doing this on all clutch jobs - just can't remember exactly where, though.
[QUOTE]Originally posted by xviper
[B]
Well, you could have but I understand why you didn't (track).
[B]
Originally posted by antek
The grease problem is already present from the factory I think...
