Clutch fork install
Clutch fork install
Just finished an engine swap, but I had no clutch fork, I installed the engine after reading Here that you can remove the clutch fork tranny in place, and now for the life of me , I cant get the clutch fork in.... Tips tricks anyone? I've even tried turning the engine a bit. I really don't want to pull off the transmission....
You don't have to pull the trans off all the way - crack the trans open, dont remove all the way or its a PITA to line up. It'll fit - dont force it, just wiggle it around until it fits nicely. I forgot to insert the clutch fork before lining up the trans/slapping it together.
Pull the trans. You will just cause yourself more issues down the road. Not to mention its hard to grease it w/o pulling the trans as well.
Billman & Slows2k say it, you do it!
I accidentally wiggled the fork loose when I was polishing the slave cyl rod end. i was in shock but I guess it didnt come all the way out as I was able to move it back into place and it works fine,
the fork can be pulled out of it's holder and reinserted without issue , that's the only way to get it on the release bearing when installing the tranny. Your experience is normal.
