clutch and flywheel setups
Old 02-11-2007, 06:57 AM
gt489's Avatar
Default clutch and flywheel setups
i have a 2000 s2k and i think my clutch is about smoked. what would be a good clutch and flywheel setup. ive always had good luck with act clutchs and would the street strip clutch be good with the spoon flywheel? who would have the best prices on these items thanx
Old 02-11-2007, 07:15 AM
S2kracka's Avatar
I personally do not like ACT products, their quality control is a little too hit-or-miss for my liking. When I upgrade, it will be a Competition Stage 2 clutch with Competition 11lb. flywheel. If you're alright with ACT products, then Hardtop Guy sells a decent package that comes with a Comptech lightened flywheels, ACT preasure plate, and OEM disk. This setup can hold plenty of power, boosted or N/A.
Old 02-11-2007, 08:12 AM
Billman250's Avatar
Received 1,399 Likes on 838 Posts
Hmm....
Of the 20 or so ACT units I've installed, all have been trouble free.
The two out of two Competition Clutch unit I've installed have MASSIVE decel buzz. Worse than than an older car which has the worst buzz from the factory.
I wonder if Competiton Clutches makes a pressure plate that can be used with a stock disc. CC relies on the disc friction, not the clamping load of the PP. That's how they achieve the soft pedal and great bite.
Old 02-11-2007, 08:48 AM
AP1_S2k's Avatar
Competition Stage 2 clutch is the clutch that I am running with the 9lbs. flywheel I love the set-up and it is great as a daily driver
Old 02-11-2007, 09:03 AM
cdelena's Avatar
The CC unit I had generated a lot of dust and a little slip. I sanded down the FW and PP and installed a OEM FD and I have the best clutch performance I have had in this car. Two years and 10K miles of hard city driving with a couple of track days with no problem.
Old 02-11-2007, 09:51 AM
kane.s2k's Avatar
Competition Clutch stage 2 on the civic and ironman on the S2000 still with no issues at all and gobs of grip.
The ACT's also have their share of cases with buzzing:
https://www.s2ki.com/forums/index.php?showt...0&#entry8529212
As well as OEM setups:
https://www.s2ki.com/forums/index.php?showt...0&#entry7738812
It's all hit or miss. Also having a messed up drivetrain system doesn't help with noise.
Old 02-11-2007, 02:14 PM
gomarlins3's Avatar
I went with the HTG set up:
http://www.hardtopguy.com/store/product.ph...34&cat=0&page=1
Old 02-11-2007, 03:29 PM
kaleyart's Avatar
Okay, I have to ask because I've been looking as well. I've looked at the ACT set up because it seems to be the most talked about, but has anybody herd of or used the (Cusco Hyper) or the ( Center force dual friction)?
I'm really wanting to do a Comptech SC in the near future, but waht to be set up first.
I found a place, (www.modacar.com) and they sell all of the above.
Any feed back on these set-ups would be appreciated.
Old 02-11-2007, 03:32 PM
kaleyart's Avatar
Oooops! I should have used the spell check before posting but you know what I mean.
Old 02-11-2007, 04:03 PM
AP1_S2k's Avatar
Stay away form centerforce
Quick Reply: clutch and flywheel setups
