clutch fluid
Either is fine.
ATE is best in there hands down (i have see in last over 5 times as long in countless cars)
Type 200 is undyed super blue. Best advice is get the type 200, do the brake and clutch fluid.
Received 1,751 Likes
So some mixing of older Honda brake fluid is okay? If I use the easy Billman method of draining clutch reservoir and refilling (with ATE) a number of times over time, I understand there should be no issue, correct?
Is there any appreciable difference between Honda DOT 3 and the cheap DOT 3 stuff I get off the shelf at O'Reily's? I've been changing my clutch fluid every 1000-2000 miles with the turkey baster method to keep it clean.
Originally Posted by S2KBert
Would you recommend then type 200 yellow or the the oem honda
I'm currently running Valvoline DOT3/DOT4 synthetic brake fluid. Can I just suck out the reservoir and fill with ATE 200 Gold DOT4?
You have to bleed the clutch line if you let it get bad(from not changing) or you change anything in the clutch hydraulics, but if you just replace the reservoir fluid semi regularly, you'll keep from having to flush the system. Just remove old fluid, clean reservoir fill with new fluid, pump clutch like 50 times with the car off, then drain and fill again. Do this like 3 times a year if it's your daily.
