Clutch doesn't disengage correctly
Just a thought. The clutch pedal has an adjustment, did you move the screw around before, while, or after the clutch replacement? If that screw is adjusted to far inward the clutch will stay engaged.
Originally Posted by listed,Oct 12 2007, 04:54 PM
By inward what exactly do you mean. I have it adjusted now so that it is in the master almost all the way. Do you know what I mean?
Well I have spent some time with this now and got alot better pedal feel along with at least 3/4" movement on the clutch fork and still no disengagement. There must be another problem here.
Lot of guys bend the disc during the installation by hanging the tranny off the disc, and horsing it around to get the pilot shaft of the tranny input engaged. The cocked disc splines now drag and so does the disc as it has a big wobble back and forth between the pp and flywheel. Hope that it's not your prob too as you'll need new disc.
I've seen bad new ones too. Usually cheap aftermarket though.
