clutch change question
Is a transmission jack necessary when swapping out the clutch or will a floor jack and some 2x10's do the trick?? I just don't want to spend 200 bucks if I can do it with a floor jack. Thanks in advance.
ChefJ,
I just changed my clutch this past weekend. I placed a jackstand out back by the driveshaft and one of those aluminum jacks with a 6" 2X4 on the saddle and placed that under the bellhousing (actually between the Bhousing and where the gears are) ... I lowered the tranny little by little with the jack and then when it was low enough I picked it up and removed the jackstand ... Its not a big deal, just make sure you do it slowly and dont drop it
.. I placed a few 2X4s on the floor by the sides in case it rolled off the jack ... Its not that heavy.
Joaquin
![hello.gif](https://www.s2ki.com/forums/images/smilies/hello.gif)
Joaquin
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
i use this tranny jack i got from Harbor Freight for $60 and it works great. its hard to get in the right position to lift the tranny with out the jack.
more pics here -> http://gotspeed.110mb.com/2001_s2000_clutch.php
![](http://gotspeed.110mb.com/images/2001_s2000/clutch/f.jpg)
GoP-Demon
05-10-2018 10:23 AM
