clutch buzz on start up
Old 02-04-2009, 07:20 AM
  #31
vollrathian's Avatar
Originally Posted by bradskee,Feb 3 2009, 08:50 PM
Its the starter sticking for a few seconds. when my car was at honda for servicing they had to start it first thing in the morning and it had that quick grinding sound as usual, the tech without hesitation said "your starters sticking". he then proceded to mention its fairly common (as we can see from response from this thread) and said its not really anything to worry about. its just the starter staying engaged a second too long.
o ok great thanks for putting this issue to rest
Old 11-11-2010, 05:29 AM
  #32
JLUDE's Avatar
Instead of creating a new thread I'll post here.
My MY 2002 just starting experiencing a sound on cold startups when the temp is below 35 degrees and the car has been sitting at least over night.
The sound I would describe as a "Screech" and happens the moment the engine fires and lasts only 1/2 a second. I'll try to get someone else to start the car for me next time I start it cold so I can listen for it under the hood to try to pinpoint its location. Really sounds more like a tensioner than a starter sticking to me. I had a failing hydraulic tensioner on my 2001 Honda Prelude and it would make a similar sound on startups.
Seems to me that a sticking starter would make more of a grinding sound, not a screech.
Old 11-11-2010, 08:48 PM
  #33
Matt15's Avatar
i find that if you let off the start button just before the car is actually started, it fires up without the grind. it's hard to get used to but seems to be working for me so far. just remember, this is only when the car is cold
Old 11-12-2010, 08:24 AM
  #34
JLUDE's Avatar
If that's working for you it's proof that your sound is caused by a sticking starter. I will experiment with that and see if it makes a difference.
Old 11-12-2010, 09:57 AM
  #35
dammitjim's Avatar
Is it possible the noise is coming from the accessory belt?
Old 11-12-2010, 09:04 PM
  #36
Matt15's Avatar
keep us posted... so at least i'll know i'm not imagining things
rambo36
09-20-2011 07:14 AM
Tony Torque
02-24-2011 06:26 AM
SVtec
12-15-2008 10:11 PM
Tom Jr
06-20-2005 12:17 PM
blacks2k
11-08-2001 04:00 AM
Quick Reply: clutch buzz on start up
