Clutch buzz
#22
Originally Posted by ~blacks2k~,Sep 23 2010, 07:59 PM
^ don't forget to grease the splines on the input shaft as well!
#23
Yeah you will likely be fine for a few years but you may run into a problem down the road if it is under-greased. I remember mine looked about as bad as this:
When they get rusted badly it causes the clutch to drag and makes shifting super difficult. I think the input shafts are under-greased from the factory as I have heard of quite a few people having issues with shifting due to rust accumulating on the splines.
Anyways, not to worry you or anything I'm sure a little WD-40 will do ya
#24
i ran the stock clutch til it gave out.
clutch buzz is nothing, might get annoying at times when downshifting and decelerating but live with it til you use up your OEM clutch.
Now i have an ACT which likes to chatter when not engaged..
#30
i have an act and after about 7k i started getting a horrid, rediculous clutch buzz. called act and they said they redesigned it and the new model won't have that problem.
told them im not paying 600 more for a clutch you guys had to re-design, can i get it for free... your product sucks. they said no.
don't ever buy act.
at this point, i'd go SPEC.. American based, and the domestic guys like it.
aem makes clutches now ? guessing you meant act. but yea
don't ever buy act.
