Clutch Buzz
Old 12-29-2008, 07:39 AM
Infidel99's Avatar
is it like a vibration from transmission coming up thru the shifter?
Yep, that's it exactly. Someone wrote a blog on the science of how and why it does it. Way to technical for my feable brain. Bottom line - it vibrates, the transmission ampliflies the sounds and since it sits between the two seats, you notice it pretty quick. And it's worse with the top up because the sound is amplified.
I am looking at getting some Quietcar and coating under the carpet and console to reduce the sound. (type quietcar in the search tool and you'll get the goguge on it. looks impressive)
I took my car to S&R, the local performance shop in Tampa, and had them look at it. They verified that there was no metal shavings or anything. So other than the sound, I am good to go.
Old 12-29-2008, 08:45 AM
iDomN8U's Avatar
no issues here, knock on wood
Old 12-29-2008, 02:53 PM
Slows2k's Avatar
To those that have an original clutch in your 02 and later car, the noise made under decel is nowhere close to the noise made by the 00-01 clutches.
Old 12-29-2008, 04:14 PM
RedY2KS2k's Avatar
If people aren't asking what's wrong with your car, you don't have the TSB054 buzz. If you have it, they will ask you what's broken.
Old 12-29-2008, 04:20 PM
Slows2k's Avatar
The Clutch buzz in a 00-01 car is unbelievably loud.
Old 12-29-2008, 07:04 PM
s2k_ed's Avatar
i have a 2000 and i dont think i hear any clutch buzz? is this a recall? is there any recalls for s2000's?
Old 12-29-2008, 08:05 PM
aport's Avatar
That's what I figured. Mine is quite faint and I can not notice it with the top down or the stereo on.
Old 12-29-2008, 11:10 PM
Dynamiteboy's Avatar
I just bought a 2000 S with a lot of clutch buzz. Can I go into the dealership and get them to replace it? Does it have to be under warranty? I just had my taillights replaced through a recall and was wondering if the clutchbuzz can be done also.
Old 12-30-2008, 04:22 AM
Slows2k's Avatar
The TSB 00-054 would only be covered if the car was still under the factory 3 year 36K warranty.
Old 01-04-2009, 08:33 PM
Russtwok's Avatar
I have a similar problem, but i don't know if its my clutch. It only happens in 6th gear and it sounds like something is rubbing/grinding. It only happens after I hit like 80 and then let go of the accelerator and then i hear it. In neutral i hear nothing so it can't be my tires. My question is, is it the clutch going out?
01Ap1S2k
01-25-2011 01:41 PM
Suits
03-07-2010 02:11 AM
METATRON
08-31-2006 12:27 PM
SandyS2K
06-29-2004 04:01 PM
dundonr
09-02-2003 09:41 AM
Quick Reply: Clutch Buzz
