clutch buzz
clutch buzz
Sounds like its getting worse When I first had the car it only was heard on second gear and now its even on third when in decel. I know it has no harm but whats making it worse?? Does an 05 have a tsb, looks like its only on the ap1s right??
Originally Posted by samackroyd,Nov 14 2006, 11:06 AM
I am no expert, do you not still have a warranty cover with a MY05?
From honda.com:
[QUOTE]
Torrance, Calif. March 16, 2006 --
Accord*, Civic, CR-V, Element, Odyssey, Pilot, Ridgeline, S2000
Originally Posted by s2kv,Nov 14 2006, 11:08 PM
I do still have the warranty, so they should replace as necessary right?? The tsb looks like its for 2001, but they still should cover it right
Many dealers consider the clutch to be a wear item and will not fix an "aesthetic" issue. I would certainly give it a try - just be sure to remain calm and reasonable. You may ask to escalate the issue to the service manager, but there are no guarantees that he/she will be more sympathetic than the service writer.
Good luck.
Good luck.
Clutches, tires and brakes are wear items. They are not covered by the 3yr/36K warranty.
All models after 01 have the improved disc installed. Whatever noise you are hearing is not the same as the 00-01 clutch buzz, which is distinctly louder than all the later clutches.
