clutch bleed fail
Old 09-07-2010, 08:00 PM
Frez2k's Avatar
Default clutch bleed fail
I went to bleed my clutch today after work and thought it would be really easy. Well i also thought that the slave cylinder would be a little easier to get to. All i had was the jack to my car, and after about 30 minutes of trying to get a tube around the bleeder i gave up. My friend has jack stands which i was dumb not to use thinking it would only take 5 mintues, but how do i go about putting the jack stands up if they are too tall for the jack i have for my car?
Old 09-07-2010, 08:06 PM
Carbon Blue's Avatar
I use 1.5 ton jack stands and I just barely get the car over them with my craftsman low profile jack which lifts roughly 15 inches. So you'll either have to get a jack that will lift higher or a jack stand with a lower standing height.
Old 09-08-2010, 12:33 AM
MrChoi's Avatar
5 minutes or 5 seconds you should always use jack stands if you are under the car. maybe you can use a piece of 2x4 or even a 4x4 so your stock jack can lift high enough to place jack stands.
Old 09-08-2010, 01:15 AM
240toS2k's Avatar
When it bled my clutch a couple of days ago, I jacked one side up and put 2 jack stands on the frame rails on 1 side, put wheel chocks 2 wheels which I didn't lift. I have a low profile jack but it got the car high enough to let my 3 ton jack stands get under and lift up 2 clicks. I lifted the driver side btw. Also an easy way to bleed is just to unbolt the 2 12mm bolts and let the slave cylinder hang.
Old 09-08-2010, 07:29 AM
Frez2k's Avatar
great idea on letting it hang, thanks everyone
Old 09-08-2010, 09:35 PM
Opc
Opc's Avatar
never, never use just a jack. thats how most people die is the jack rolls, it's a 3,000lb car being held in place by a 25lb jack.
you do the math. be safe man, dont ever do that again.
Old 09-08-2010, 11:57 PM
MrChoi's Avatar
s2000 is not 3000lb plus you are only lifting maybe half of its weight. there is no reason why the jack will roll unless you are on a hill but yes never work under a car with a load on the jack only. always jack stands please.
Old 09-09-2010, 11:19 AM
NoRegrets78's Avatar
Good friend of mine almost died when his jack failed and no jack stands were present. Miracle he survived after being crushed like that.
Old 09-09-2010, 01:45 PM
emac0408's Avatar
Bled clutch + no jack stands = bled head
Old 09-24-2010, 10:21 PM
unison21's Avatar
Even with jack stands you have to be careful. I take extra precautions by using jack stands, wheel chocks, partial load on jacks in case jack stands fail, and wheels under the side in case those fail.
See thread about a member who passed away working under his car:
https://www.s2ki.com/forums/index.php?showtopic=785922
Quick Reply: clutch bleed fail
