Clutch Arm Dimensions
If anyone has a bellhousing out and can check the clutch arm dimensions for me I would be grateful.
I'm trying to mate to a transaxle that currently has a push type throw out bearing to a pull type arm.
I want to modify the transalxe with an arm that pulls but need to know:
1:Overall arm length
2: Distance from pivot point on bellhousing to the end of the arm at the throw out bearing.
I would also like to purchase an arm if one is "laying" around.
Thanks in advance - my other alternative it to switch over to a K24 flywheel and clutch set up - but this seems like a less costly way to go.
Briggs
Briggs
cjts2000
06-28-2018 11:18 AM
