Clutch adjustment question 1000 (but a new one)
#21
fairly certain. It also seems like it’d be a non-factor. The CMC is offering the right amount of resistance, and the plunger on the CMC is where it belongs, so I’m thinking it has to be some part of the pedal that is misaligned or improperly adjusted
#28
I've never had to do this on my s2k, but the thing that I'm not hearing you say is whether or not you have adjusted the pedal height. If it's set high, then the rod has to be extended to reach the pedal arm. There should be a simple bump stop that limits how far up the clutch pedal will go. If you can adjust it so that the pedal doesn't come up so high, it should solve the problem.
#30
