clutch adjustment
I think that there should be some amount of free play. It can be close to zero, but not zero. If the play is truely zero, then even touching the clutch pedal at all between shifts will engage the master cylinder and throw out bearing.
My clutch did not engage properly IMO when new and was even worse after a clutch replacement without a pedal adjustment. I was able to get it right by making the stroke longer and adjusting so there is a little play in the pedal.
