Cluster out, top won't go down
My gauge cluster went out the other day, it's flickering ever so faintly though.
I dont have a RPM, speed, fuel, temp... nothing.
My top won't go down either.
I was doing some reading and i think it's related to the Vehicle Speed Sensor (VSS), has anybody else had this issue?
any help is greatly appreciated
thanks
thanks
update:
With the key in the on position and if you turn the lights on you hear a bunch of rapid clicking sounds coming from behind the cluster. Only when the lights are on though and the key is in the acc on position (doesn't do it in the run position). The lights do work though all of them
EXCEPT the rear side led running lights and the front running lights are flickering all dim like at the pace the dash is flickering, only when the lights are off though.
I guess it could determine that if the vss is faulting if i did the mod and the top would then work.. hmmmm...
(the top is currently up btw no worries there).
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
i cut the vss wire and the top now goes down. gauges are still really messed up. getting a new vss tomorrow
oh and thanks for the help dude
