Cluster is blinking !
Hello guys,
i have a problem that once i start my car the cluster blinking !! .. and if i step on the gas it work normal ...
any ideas why and how to fix it ???
Is it just while the car is cranking or does it stay blinking once its on? If it happens while your starting it its normal, but if it flickers then it could probably be your alternator going out.
have you tampered with it? any bad connections? have you installed a new radio recently? if so the dimmer (or orange or orange with white stripe) wire in the aftermarket radio may need to be disconnected if you used it. Also, there may be an incorrect wiring if you installed a new alarm. If its none of these, the LED's in your cluster may be going, and causing shorts. If all that has failed, the dimmer switch on the cluster. or the headlight switch may need replacement
no new radio but may from the headlight because i switch the rear bumber with the new 2006 wih the lights ... but is was working fine , recentlly i faced this problem ....
Might not be the alternator, I have the same problem on my 07 with 14k miles. I swear to the Honda Gods if my alternator is going out already I will punch Honda right in the face!
