Clunking sound when coming to a stop in first
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
When decelerating with the clutch pedal pushed in still in first gear there is a shake and clunking noise. I have also noticed a difficulty in downshifting even at lower rpm. I just changed the diff fluid and tranny fluid. Mobil 1 75 90 diff and GM synchromesh in the tranny. I don't know if it is the transmission or the diff or what. Can anybody shed a little light. Thanks alot. James.
I had a mechanic friend drive the car and he thinks that the clutch is not disengaging. It does it in any gear when coming to a stop. Anybody ever have this happen?
It is not hard to pull out of gear into neutral. It only makes the sound when I am almost at a stop. Sometimes it is hard to put into gear and downshifting is a pain. Accelerating and upshifting is normal most of the time. It doesn't clunk if the car is in Neutral when coming to a stop. I don't think it is the tranny or diff anymore just from what I read about them when they go out.
hopefully you don't downshift from 2nd to 1st. i know there are some people that do that, to me it seems it puts too much stress on the tranny. lowest gear i'll downshift is to 2nd and every downshift i d/c and rev match the car.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
When did you last replace your clutch fluid, it could be air in those lines. I'd bleed the clutch and go from there.
Originally Posted by jesusphish,Oct 1 2006, 03:30 PM
78000 miles.
If you don't rev match, or if you do and not properley I am willing to guess the spring retainer on your friction disk is broken.
It probalby looks like this
![](http://s2ki.iroque.com/Jasonoff/brokenfd.jpg)
