clunking passenger rear
the only modification i have on my vehicle is a coilover system. purchased brand new.
i checked components of my suspension and everything is tight, not blown, and my bushings are in good shape. the sound seems to be coming from inside the vehicle also. any ideas? thanks in advance.
Did you try your axle nuts?
Mine sorta pops a few times on bumps, and now its to the point where it pops a few times just taking off. Its also coming from the passenger rear. I tried to tighten everything but nothing is loose. Most people said try the axle nuts because it will cause a noise like that. I just need to go get a 36mm socket and torque it to 220ft lbs.
