cloud of white smoke
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
ok so this is the issue: White smoke comes out sometimes when im in heavy stop and go traffic and when I shift into reverse and start backing up. This is not a constant thing where its always throwing out white smoke but it usually happens most of the time. I take well care of my car as in oil changes every 2500-3k miles and use castrol synthetic 10-30, K&N oil filter, 5 min motor flush, 1 Quart synthetic additive I think its called lucas, engine restore (4 cyl) can, and a Fuel system cleaner. I don't "tear" up the streets with it, usually never in VTEC, have 86k miles on it, have Ricks headers, test pipe, and apexi N-1 exhaust, no tune. Any advice on this should I be worried or not even bother to care about it?
No I don't, may I ask what does that have to do with it because my coolant reserve tank usually is at the level it's suppose to be on the full line.
If it makes you feel any better, my first mod was a test pipe.
I bought my S new in 02. Put the test pipe in with ~10k on it, it would smoke like crazy sometimes at stop lights![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
You should be OK.
You should be OK.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Take a vid of the white smoke and post it. Many people think that the condensation that the warm exhaust gasses make is "smoke"...but it's not and it's nothing to worry about.
It could be other things like stated above...but my car would SMOKE (white) at stop signs (sometimes) with a test pipe as my only mod.
If your not losing coolant, its not coolant causing the smoke.
i too also have this problem but one of my friends that is a tech at a honda exclusive shop and he thinks it could be my rings going out.. i really hope hes wrong but i just replaced my head gasket about 7k miles ago
