Clicking sound?
Old 08-24-2004, 08:49 AM
Bear 04's Avatar
Default Clicking sound?
I hear a clicking sound from the rear wheels at slow speeds 2 to 5 mph. I jacked up the car and rotate the wheels but no sound.....What could this be??????
Old 08-24-2004, 09:04 AM
xviper's Avatar
Could be loose hub nuts. There is a TSB on this. Go to the dealer to get it checked out.
Could also be wheel bearing or CV joint. Lifting the rear off the ground unloads things and the noise may not be reproducable this way.
Or, it could something as simple as a small rock in the tread just in the right place.
Old 08-24-2004, 03:32 PM
Bear 04's Avatar
Its definitely not rocks in the tread, the sound is too uniform and I checked the tires when I had the car up in the air.
Old 08-24-2004, 04:46 PM
ahbongkadah's Avatar
Its a pretty common problem with s2's. Just greasing and re-torqing the axle nut should solve the problem... Theres another thread on this same page that address' the same problem... Or do a search there was a really good thread on it a while back.
I would fix it as soon as possible, after a while it causes unneccessarry wear in the wheel bearing. THen you end up having to replace that along with the hub.
Old 08-24-2004, 05:50 PM
alexf20c's Avatar
Do the wheels groan once you get to cruising speeds (50mph+)? Wheel bearings...
Is the clicking only at walking speeds, or when turning/reversing? CV joints...
Can you feel the clicking in your gas pedal or in the steering wheel?
No point in replacing something that doesn't need replacing; find out what the problem is, first.
Old 08-24-2004, 05:57 PM
PLYRS 3's Avatar
that's alex's brain in overdrive....
sorry, couldn't resist.
Old 08-24-2004, 06:03 PM
alexf20c's Avatar
I don't follow.
Am I supposed to flip out and throw you a poor-taste insult? Or am I supposed to expand on your joke with a witty comeback?
Old 08-24-2004, 06:04 PM
alexf20c's Avatar
BTW, you trade your cars more often than I get banned from S2ki.
Old 08-24-2004, 06:13 PM
PLYRS 3's Avatar
i know, i know....i ain't none to happy about it either (my cars, that is )
it's REALLY hard to find a keeper.....
Old 08-24-2004, 06:15 PM
buzilanga's Avatar
I have the same prob, now I can't check it cause my car is back home in my country and i'm in the US now. But I know I read a thread that it can be your breakpads too?
Quick Reply: Clicking sound?
