Clicking noise from rear driver wheel, varies with speed
I removed my wheels for the first time to do a brake bleed two weeks ago, and have since discovered a light clicking noise that varies with speed from the rear driver side wheel. It's audible under 25mph or so, only with the top down. I double checked the torque on the lug nuts (80 ftlbs) but that didn't help.
I have already done the rear axle nut "TSB", well before this problem occurred (never showed any symptoms but did it as preventative maintenance).
Any ideas?
Any ideas?
Is It a repetitive clicking or does it happen every once in a while? I would check for play in the wheel and try the rear axle nut TSB again, but with a higher torque value.
It's a repetitive clicking. It sounds like its happening with every rotation of the tire. Found that it happens going forward in gear and neutral, but not when reversing.
Might be one of your transmission shaft bearings.
