Clicking during right turn
I am experiencing a clicking noise during a hard right turn. Along with the noise, i have a slight vibration while driving. Nothing happens when i make a hard left turn. So this leads me to believe that my driver side inner cv joint is bad. If its something else feel free to post. Honda wanted 300 for one joint, are there cheaper places?
Drive bucket on the top right. The part on the bottom right is the axle, which will stay on it's original side of the car. Take the buckets off only, and switch them from left to right.
Tool on left is used to break the ball joint.
I just recently went through the same thing. Hard right turns I had a clicking sound and somtimes heard a sound like brakes scraping only the scraping did not change whether I was braking or not. The sounds were inconsitant and always from the left side. It ended up being the left side wheel bearing.
im going to check that first because about two weeks ago my axle nut was loose, and i mean loose enough the rotor and wheel were able to move. So maybe the bearing get messed up during that.
Well, i got the hub off and the bearing is shot. There is close to a cm of movement in the bearing. So.... (let me know if more information is needed) what do i need to replace? just the bearing or is there more?
saliv8
06-11-2002 07:00 AM
