View Poll Results: Click/clunk noise normal?
Yes!
42.86%
No. . ?
57.14%
Not Sure
0%
Voters: 7. You may not vote on this poll
Click/clunk noise when changing directions
Old 06-27-2008, 04:19 PM
King_'s Avatar
Default Click/clunk noise when changing directions
When ever I am going forward, and I stop and back up there is a funky noise. it also does it when I go in reverse, stop and go foward. also does it sometimes from a stop and then going in either direction.
My bestfriends S does the same thing and so did his old S that he had.
Anyone know?
Old 06-27-2008, 04:26 PM
RISLAR's Avatar
I voted no as this is the hub nut, you need to tighten is, its a 5 min job fella
Old 06-27-2008, 05:02 PM
SpitfireS's Avatar
If this has been going on for a while it's better IMO to remove the rear axle from the hub, clean the splines (on axle and in hub) and grease them, grease the thread and THEN tighten the axle nut to spec.
Old 06-27-2008, 06:31 PM
SCCS2K's Avatar
Yep, hub nut. Retorque to 220 lb/ft will probably do it for a while, but I also recommend what Spitfire said. And get new nuts while you're at it, they're only a few bucks.
Old 06-30-2008, 06:27 AM
chinkieboy's Avatar
i have the same problem here. anybody got a DIY on this? or recomm. take it to dealership to get it done?
Old 06-30-2008, 07:16 AM
SCCS2K's Avatar
https://www.s2ki.com/search/forums?query=ax...=&forum=&topic=
This forum is LITTERED with DIYs. There's even a TSB in the FAQs. In fact, one post up from yours, in this very thread, I say to retorque the hub nuts to 220lb/ft and that'll do it. I also recommend buying new nuts while you're at it.
Old 06-30-2008, 07:33 AM
chinkieboy's Avatar
hub nut is it right behind the center cap?
Old 07-01-2008, 05:30 PM
King_'s Avatar
Thanks for the info everyone! a lot of help!
Old 07-02-2008, 03:38 PM
billiardboy904's Avatar
I have had this problem multiple times. I first had it for about 6 months, i changed my hub nuts and did torque to the correct 220 ft/lb's The problem came back after a month or so. So i bought new Hub nuts again and this time after torqueing them, I made sure to pound the divet in very good. The problem came back again.
I keep being told it is the Hub nut but i disagree. Anyone have any suggestions? i dont hear hub squeal, just the click when i change momentum such as start, stop, and reverse.
Old 07-02-2008, 10:59 PM
mugenrsx's Avatar
Looks like they've got you covered. I just had this problem fixed not too long ago. Sufficient bitching and moaning to the dealer will land you 2 brand new axles! Ask me how I know. =)
Quick Reply: Click/clunk noise when changing directions
