Cleaning Oil Pan for Mods
Can you guys tell me what is the best way to clean up and old sump in preperation for welding in a baffle and boss for the oil return from my Comptech supercharger?
Originally Posted by thetz99,Aug 12 2007, 12:12 PM
I used a wire wheel.
hot tank because i have an access to one, it took no time and it's so clean i can eat off that bast@rd
Originally Posted by iam7head,Aug 12 2007, 04:10 PM
ouch
Originally Posted by thetz99,Aug 12 2007, 03:17 PM
15 minute Wire wheel on aluminum takes off all the buildups, followed by metal polish Gives a nice brushed aluminum look if you don't do any other polishing
it too easy to overdo it when you can see it getting shiny and shinier just by triggering the drill.
Originally Posted by Slows2k,Aug 12 2007, 07:22 PM
Non chlorinated brake cleaner works well.
Not keen on the wire brush idea.
I don't like the finish, doesn't get in to all the tight areas, it spreads contamination and can damage sealing surfaces.
A dremel with a wire wheel gets into the smallest nooks and crannies.
Dust contamination is a major world issue
You use thick gooey hondabond when you seal up a oilpan, residual sealant on a sealing surface is more a problem than a cleaned one
You should worry more about the toluene, acetone, ketones, methanol, and other volatiles found in your average brake cleaner if contamination is really a concern of yours
