Cleaned IACV - Parts Fell Out?
Pretty confident I found my stalling issue. Opened up the motor side and these two shims fell out, any idea how they go back in? Also, what oil should I use for the bearing. Thanks!
I did this a few months ago. This video at 1:57 shows where the shims go back (good thing you didn't loose them!)
For the bearing oil use sewing machine oil, or any very thin oil. I would also highly recommend replacing that rubber gasket. The video I linked above was a huge help for me.
Update
This solved my problem. Symptoms:
Once the warm-up idle cycle was completed, the car would bog and have trouble trying to find idle, especially when revving down. When it did it would have a very low idle and shudder. This was most notable when pulling in to a parking space, the car would basically just shut off as soon as it was stopped.
HarryD (06-04-2018)
https://www.s2ki.com/forums/s2000-un...-943369/page2/
I also took apart and cleaned the throttle body channel that runs from the MAP sensor. My stuttering and almost stalling is completely gone.
S2KCHRIS305
02-06-2015 02:58 PM
