Clacking noise after oil change
#21
I'm using the OEM PCX-004 filter so I don't think it's that. When I changed the oil from 10w40 back to 10w30, I emptied the filter and there was oil in it and a decent amount too.
The oil I'm using is conventional Castrol GTX 10w30, I've been using it since I bought the car with 56K on it, now has 97k. I switched to their GTX High Mileage to lessen the oil burn-off around 80k, it helped a bit. I don't think the oil is the problem anymore either.
I had the valve clearances checked right after the noise appeared, I think he said cylinder 2 & 3 intake side were a bit off so he put them back to spec. He checked the oil pressure and I believe he said it was about 40 at idle and about 90 at 3Krpm.
The rattle is intermittent and only on cold starts. I do have a bit of loud ticking coming from the intake side of the cam chain case when cold, but I think that's normal as it goes away too, plus I think I'm just getting paranoid at this point.
here is another video that is almost identical to what my noise is like, thanks to dustin02rsx for finding it
http://youtu.be/-H4EPpsKfOw
the video poster said it was just common valvetrain noise, but I'm a little skeptic since it just appeared suddenly.
I'm hoping this noise is just normal, and something that comes along as the engine ages. But the paranoia is still there lol
