Cigarette lighter stopped working and radio went out
Banned
So i got a flat and I used my craftsman tire pump using the cigarette lighter worked fine and then it just stopped working, a couple mins later on the way home i went to turn on the stock factory radio and realized it stopped working but the little anti theft light was blinking. Got under my dash pulled the 15a fuse for the radio and it seemed fine but just to double check i took out a 15 fuse for the washer motor and put it to the radio and still nothing and the red anti theft stopped blinking. Anyone have this problem or know how to resolve this?
Banned
So each bulb works from the buttons, but what about the switch on the dome light assembly. Be sure it is not off, instead of in the middle set to "door". Do they light up when you push the switch all the way right to "on". What about when you unlock the car with your key fob?
Banned
There is also a sticky in the DIY but that write up didn't have pictures so i posted the above write up instead. Should fix it.
Banned
Originally Posted by keviinbraah017' timestamp='1394940931' post='23064797
[quote name='T-S.M.A.C' timestamp='1394940306' post='23064784']
[/quote]
Appreciate it, I got everything working again. Thanks!!
