check engine from test pipe
Old 05-11-2004, 07:05 PM
JAYZS2000's Avatar
Default check engine from test pipe
I installed a test pipe and my car is showing a check engine light. I was pretty sure this would happen, but I heard if you remove a fuse it will not set off the check engine light. Anyone know which fuse it is I should pull or have any other ideas on how to not trip the check engine light.
Thanks
Jason
Old 05-11-2004, 07:12 PM
sebrings2k's Avatar
pull the back up fuse
Old 05-11-2004, 07:30 PM
dut
dut's Avatar
- or you can get an o2 sim to trick the ecu
Old 05-11-2004, 09:23 PM
duff0000's Avatar
Ive also heard from a friend you can cover the part of the o2 that goes into the testpipe with aluminum foil, and it will not cause the cel. never tried it though, has anyone?
Old 05-11-2004, 09:46 PM
xviper's Avatar
Pulling the BACK UP fuse will cause the car to run poorly, idle badly and will not allow the ECU to be adaptive, so if having no CEL light is more important than these things as well as never knowing if your car will ever have a real problem, then go ahead and run without it in.
Old 05-11-2004, 09:57 PM
dut
dut's Avatar
- hmmm.. someone needs to test that foil theory..
Old 05-11-2004, 11:38 PM
tru
tru's Avatar
i seen the foil work on wrx's
Old 05-11-2004, 11:46 PM
Silvers808's Avatar
the foil didnt work on my turbo civic.
Old 05-12-2004, 11:17 AM
Former Sponsor
Gernby's Avatar
Look for an ECG 5-wire O2 simulator. They work fine, and are <$50.
Old 05-12-2004, 11:44 AM
Runaround's Avatar
you can get that ecg 5-wire O2 sim here:
http://www.wiredspeed.com/index.asp
Quick Reply: check engine from test pipe
