Check Engine Light and whistle off the AEM intake at hose and sensor HELP need info
Originally posted by dreamcation
I always remember to give the cap a good 5 to 6 turns.The best way I can describe the hissing is it sounds a lot like a very weak BOV that dissipates after the car's warmed up.
Try to distinguish it from the normal intake whistle.
Dude I have the same problem, When the car makes that bov sound right after I start the car check engine comes on but when the bov sound comes like a min. to a min. and a half after I start it it goes the light doesnt I don't get it, sometimes I want to send the car off the cliff !
XVIPER - Try to distinguish it from the normal intake whistle.
I have a MY00 with 28k (bought used at 25k) in Tucson, Arizona (very dry hot desert) and was starting to get concerned about dried out and cracked vacuum lines because of this whistle sound. But, the car runs great.
Originally Posted by intake,Jul 13 2004, 04:48 PM
Just installed cai and i have hissing on cold start up but goes away after a minute or so.No lines are crossed or kinked any ideas
The reason why the noise goes away after a minute or so is because it is associated with the secondary air injection system. This system only works after a cold start and shuts down when the intake manifold detects the correct temperature. I'm surprised that you can hear it now when you could not before the CAI. If you can hear it that well, I'm also surprised that you don't have a CEL. Are you leaving out any details?
