Check engine light on......reset???
Old 12-11-2001, 11:49 AM
socal28's Avatar
Default Check engine light on......reset???
Over the weekend, I was wiping off the dust off the AEM intake. After a couple of hours of driving, my check engine light went on. Then it hit me.....damn...must have knocked off one of the small air hoses off the intake. Came home and checked and sure enough, one of the hoses that runs to the bottom side device was off. I put it back on and started the engine. The engine check light is still on! Been on now for several days now. Looked everywhere else and couldn't find anything. The car seems to running normal.
Is there a reset for the check engine light? What else could it be?
TIA!
Old 12-11-2001, 12:10 PM
Prolene's Avatar
There is a reset; after a fix of the situation that caused it, it will not reset by itself. Disconnect the battery a while or pull a fuse as per S2000 Manual; search threads to find which fuse to pull.
Old 12-11-2001, 12:36 PM
RT
RT's Avatar
Second fuse down (third slot) on the right side of the drivers side foot well fuse box. It's marked "Back-Up".
Old 12-11-2001, 01:14 PM
Schatten's Avatar
Prolene - its in the FAQ section. =)
RT helped me on it when I had an issue. Just read the FAQ and it should help idientify if its a fluke or if its a real issue (which it will come back).
Old 12-11-2001, 01:29 PM
Prolene's Avatar
[QUOTE]Originally posted by Schatten
[B]Prolene - its in the FAQ section. =)
Old 12-11-2001, 01:54 PM
socal28's Avatar
Cool! I will give that a try!
Thanks guys!
Old 12-11-2001, 08:07 PM
socal28's Avatar
It worked! Check engine light is gone!
Thanks everyone for the tip!
Old 04-07-2017, 12:19 AM
thegolffather's Avatar
same here awesome!
Old 04-07-2017, 03:31 AM
Shameel Rudy Mohammed's Avatar
Hey bro, I am from Trinidad in the Caribbean. I have a 2000 model S2K and its on boost stock Ap2 motor with met spray and Hondata managment. I changet my clutch and pressure plate 3000 km ago and since then I am vetting vear box hum between the gear when i release the trottle. Have you ever came across such issue and solved it? You can E Mail me at archdesigntech@gmail.com please.
Old 04-07-2017, 03:32 AM
Billman250's Avatar
Received 1,397 Likes on 837 Posts
Like going back 16 years in time
Quick Reply: Check engine light on......reset???
