Check Engine Light P1404
After about 1.5hrs of driving (from school to home) my check engine light came on. I was but 5 minutes from town when I noticed the yellow light pop up. I quickly went to the nearest Advanced Auto Parts and asked them to pull the code.
DTC (Codes)
P1404
Manufacer Contrl.
Auxiliary Emission
Controls
The above is what was printed out by the machine.
I have not modded the car recently and the car is relatively stock. The only thing I've done recently is fill the car up as I had a long trip ahead of me. It is not the gas cap as I just stepped outside to check it.
Mods:
Gutted Airbox
Resonatorectomy
What could be the problem?
EDIT:
The 7,500 check up. I fixed it.
DTC (Codes)
P1404
Manufacer Contrl.
Auxiliary Emission
Controls
Mods:
Gutted Airbox
Resonatorectomy
EDIT:
Originally Posted by xviper,Jul 24 2006, 09:13 PM
I don't see such a code listed for an S2000.
I just posted what the printout said.
After about 15 minutes of poking at my car, I tried the trip reset again and the CEL (maintenance light) goes away.
The CEL and maintenance light are the same thing correct?
Originally Posted by Slows2k,Jul 24 2006, 10:01 PM
The CEL and Maintenance req'd light are very different things. Where did you ge the code pulled?
I have a feeling the code was for a previous car the tester was hooked up too.
I got the code pulled at Advanced Auto Parts.
Is the CEL the oil dropper looking thing?
Originally Posted by xviper,Jul 24 2006, 10:18 PM
If you are looking at the "oil dropper" light and went to get a code pulled, they pulled a non-existent code when your low oil pressure light was on. GOOFY!
Bury this thread deep, very deep.
Originally Posted by mugenrsx,Jul 24 2006, 10:26 PM
I was just guessing. It was the maint req'd light that came up when I went to pull a code.
ps. You can close this thread using the options at the bottom or Slow can dump it for you.
