Check Engine Light (continued)
This is a continuation of the thread I started on the temporary forum. I started getting a CEL after I installed a hondata gasket. Blinks 6 times, short. I got this from modifry's site=
P0117 0 - 6 --------------- Engine Coolant Temperature Circuit Low Input
P0118 0 - 6 --------------- Engine Coolant Temperature Circuit High Input
I have changed the sensor, reset the ecu, still get a CEL. I tried bleeding the system, reset the ecu, got a CEL after about 40-50 miles. Anything else to troubleshoot tihs code?
While blink--blink works it would be best to have someone pull your codes using an ODB-II scan tool. This would get a much better understanding of any issue the car is seeing.
Utah
Utah
I got the code checked out and it came out to be a totally different problem then originally thought. P0411 is what it came out to be. This is weird because the CEL flashed 6 times. P0411 Secondary Air Injection System Incorrect Flow. I am thinking it has to do with a vacuum line. I will double check my lines. Thanks everyone!!!
check that you have the white check valve behind the factory airbox is installed the correct way in the line. did you recently install a cold air intake or anything?
see this thread: http://forums.s2ki.com/forums/index.php?showtopic=105368
Nice animation Dut, LOL! I switched those lines and the CEL has not came on yet. I think the problem has been fixed. Thanks everyone!
BTW: 6 long blinks says that it would be the AIR PUMP, is that the air pump?
