Check Engine Light, Code P1456, Smell Gas
It should. That is the gas cap specific code and being that your cap was loose, I'm sure you've resolved the issue.
I always get a little oil off the dip stick when I'm checking oil levels during fill-ups. With your finger rub a little oil along the threads of the cap.. it'll go on smooth as butter.
for the filler neck issue, keep a small can of wd40. hit the threads on the cap and turn the cap like you would close a jar around the outer edge. I've had this issue from day one. Another trick is use the gas that drips from the pump after a fill, bottom line, keep the gas cap threads slippery.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
