Check engine light came on but no code??
Hello everyone,
I was driving my 2006 s2000 the other day when out of nowhere the check engine light came on. Luckily with COVID I didn't have anywhere I needed to be so I haven't driven the car since. The check engine light is completely solid, I don't think it even blinked when it initially came on. Just now I got around to pulling code with my flashpro and nothing came up? It just says there is one DTC and the check engine light is on but there is no code anywhere, I refreshed multiple times and checked everywhere. My mods include an HKS hi power cat back, berk hfc, and k&n intake. I was running a pretty basic tune on flashpro, tuned by Jeff Evans of evans tuning. However, i went back to stock and have been running stock tune since back in july when I needed to be stock for smog, I also took off the hfc and installed it back on the car around the same time in order to pass smog. I've never had a check engine light in my entire year and a half or so with the HFC, but thats my best guess at what it could be as my car has been problem free until now and the engine only has 59,000 miles. Any help is really appreciated as I'm a noob and starting to worry here haha. Added photos of what I saw on flashpro as well.
Thanks in advance!
Thanks in advance!
Any pending codes?
Since you don't have your own scanner yet, you can go to someplace like AutoZone, and they will read the code for you for free. They aren't allowed to clear it, but no problem reading it.
Then go to Amazon and look for bluetooth odb reader. Uses an app on your phone, and reader plugs into odb port, then bluetooths the signal to phone. Cheaper than buying a full reader device, and easier to upgrade software. Less clunky user interface as well.
Yeah skip the flashpro thing and use a code reader. The flashpro is obviously having some issues communicating with the ECU. Especially since it sees that a DTC is set but does not show what it is.
You can get a code reader so cheap nowadays. I think I paid around $30 for my wired one. You can get a BT one for around there too these days. If you are playing with cars it is worth having one in your tool bag. And it keeps you from having to run to Crapo-zone or somewhere else to have someone else pull the codes. And if the car is broken enough to barely run or not run at all, then getting it to someone else to pull the codes is not an option. You can probably find a decent enough reader on Amazon and have it in your hand in a day or two. Worth the money to have.
I used to have a PC based one (stopped working many versions of Windows ago) that was pretty cool, but 99% of the time I just grabbed my cheap one from the box and used it to read codes.
The thing you will not get as often with cheaper ones are mfgr specific code support (aka non generic codes) or you have to pay extra for those, but most of the time working on your own car you can get by with generic codes only.
Most code readers are OBDII, and read the engine control module, but may not read the body control module or any or the other multitude of computers in the car.
