Check Engine Light - ON
I recently tried to replace my air filter with the K&N air filter except the check engine light came on after messing with it. Is this normal?
I put the stock filter back in to see if the light will go away. Any thoughts?
My veh is '07 S2K.
My veh is '07 S2K.
Did you install the K&N FIPK system or just the filter? If you installed the FIPK, you probably have your vacuum lines hooked up wrong.
Take your S to AutoZone/Discount Auto/Pep Boys and get the CEL code read. (It should be free to check at those places).
Post the code.
That'll help us identify what the problem is.
Post the code.
Post the code.
Post the code.
PS - If the check engine light clears all of a sudden is that good to go?
I'd say no. Anytime you get a CEL, you need to find out what the problem is.
Originally Posted by Suzy S2000,Apr 16 2007, 03:37 PM
Great! Thanks so much!
If so, did you happen to fill the gas tank up at about the same time?
Personally, if the code is gone I wouldn't worry about it, until it comes back, but that's just me.
Originally Posted by Dave-ROR,Apr 16 2007, 01:28 PM
So did the light go out?
