Check Engine Light
Check Engine Light
Hey,
Well i had some pieces laying around with an old K&N filter so i threw it on my 02 S2000. I drove around it was fine than the next day when i started her up for work the CEL came on. After work i went by Autozone to check the code and was told it was Seconday Air Injection? Well i installed it correct and all hoses are routed the right way. Kinda confused why it came on most likely i will take it off just cause i dont like seeing it on. LMK if you have guys have an idea on the reason it came up on maybe ? thanx peace
Check those and check the little white check valve for correct direction. (second pic in this forum : https://www.s2ki.com/forums/index.php?showtopic=105368)
i didnt touch any of the hoees i only pulled the breather an put it back in the intake and i put the thick rubber hose thats connected to the oem intake into the 2nd hole on the intake. I didnt unplug or reverse anything? i also though our cars had IAT sensors in the intake like obd-2 civics an integras?
shiaochiu
01-18-2004 01:33 AM
