check engine light
Old 10-05-2006, 10:31 AM
  #71
lude9285's Avatar
Originally Posted by LATEOTT,Oct 4 2006, 09:02 PM
Any of you want to speculate in an informed way how a compression problem in one cylinder could cause random misfires in ALL cylinders?
I'm really curious how this could happen.
Are the sensors just that nonspecific? Or could a problem in one cylinder actually cause all of the other cylinders to randomly misfire?
yeah...is my already BIG problem bigger than i think. Why do i get misfires and random misfire codes for all four cylinders? Compression is only really low (100lbs.) in cly 1. Cylinder 3 isnt that high either (145lbs) but cly 2 and 4 are 175lbs.
Old 10-05-2006, 02:27 PM
  #72
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Last s2k I did a comp test on was about 220 on all for cyls.
Your cyl 3 compression is very poor, as well as cyl 1.
If the cyls leaned out, you'll get misfires across the board. 1&3 just happen to be the first to suffer sufficient damage.
As far as upgrading, You won't find anything to go the distance like stock. Even if you do, the gains are not worth it unless you build a full race motor.
Most importantly, you should find the root cause of the problem, so you don't fry the next engine as well.
Old 10-05-2006, 09:09 PM
  #73
lude9285's Avatar
thanks billman for the post......but ive spent this whole summer trying to find the "root" of the problem. Checked/ changed parts to make sure i had spark...checked fuel pressure and injectors...so ive got suffient spark and fuel. Or at least thats what the 3 shops ive had it to this summer tell me! I finally found the reason for my misfires....low compression/leakage...but what could be causing this in the first place?
Old 10-06-2006, 04:00 PM
  #74
Billman250's Avatar
Well, I said it along time ago, but the fuel trim info was vital at the time the problem started. The freeze data from the original codes would have showed if the engine was running lean.
Here's your best bet:
1. Pull the head. It's got to come off anyway. Have it vac tested, disassembled, be sure there are no damaged spots on the valves or seats.
2. Check the cyl walls. Damage is quite obvious on the FRM cyl material.
3. I would watch the fuel trim from the get-go when you're up and running again, to be sure you don't lean out (if that's what it was) the next engine.
03s2k84
09-09-2013 06:29 PM
k00kaine
10-26-2010 05:29 AM
Raza
04-02-2010 05:33 PM
JUSTINTHECOASTIE
Tampa
17
11-24-2008 01:49 PM
gravitykills
09-01-2008 08:39 PM
Quick Reply: check engine light
