check engine code help p0411 secondary injection s
I recently put a rebuilt motor in my car out of another s2000. while installing it they installed my AEM CAI, not the V2. The engine quickly threw a code and has a check engine light on.
the code is
p0411 secondary injection system incorrect flow.
the gentleman evaluating my car with the tester said the 400 codes were air intake or vaccume related. does anyone have any thoughts on this issue?> i know i need to take it back to the people who out the motor in, but they are several hours away and i won't be able to do that any time soon. thanks for your help in advance if anyone has thoughts or even a guess.
the code is
You screwed up the vacuum line routing when you did the CAI. A pretty common mistake. Go here and all the answers will be before you.
https://www.s2ki.com/forums/index.php?showtopic=105368
