Charging Issue
Charging Issue
Okay a while back I had a problem with my charging system and the end result was i had my alternator converted to a single wire.
Things replaced New Battery
x2 Brand New Denso Alternators and they were checked for charging Checked Good
Also The Battery Light would not come on with the key in the On ( I am Also running AEM EMS)
So this problem was resolved with the single wire battery. Now I want to find the real reason for the problem I have a new alternator in my garage for the car if I can find the solution.
I replaced the Battery bulb in the cluster today to make sure it works... the light still does not come on.
I checked the 15 amp fuse under the hood.
So my next questions is what could cause this and where are the other fuses/relays?
Thanks
Thanks
SimbaDogg
06-04-2019 03:48 PM
