Changing Valve Stem Seals...
Old 11-01-2008, 08:21 PM
froggie's Avatar
how about the piston rings? If you pull the head off anyways, would it be possibe?
Old 11-01-2008, 09:11 PM
ninety2slow's Avatar
The pistons and rods would need to be unbolted from the crank... So no, that would require a lot more work.
ADDED: I guess it is possible though. LOL
Old 11-01-2008, 10:42 PM
AndyThomason's Avatar
Originally Posted by luder_5555,Nov 1 2008, 11:51 PM
i would do the whole "valve cover gasket kit" it should come with new seals for the whole valve cover including stem seals.
i have never done it on the s but i just did it on the lude and the set was about $60
where can i find that?
i looked on hardtop guy, all i found there was the valve cover gasket for 22 dollars
Old 11-02-2008, 09:20 AM
luder_5555's Avatar
^ well it might be cheper on the s2k but most auto parts stores should have or be able to order it. they yook 3 days at shucks to get the one for my lude
Old 11-02-2008, 08:54 PM
Kirpich's Avatar
No, forget it, autoparts stores are absolutely useless. don't waste your time.
Old 11-03-2008, 08:04 AM
JDR159's Avatar
I would also recommend you have your valves 'reground'. That is, the machine shop that does your valve seals (and guides I hope), can relap the valves to the valve seats. This is cheap and will essentially finish your head...
Old 11-03-2008, 01:07 PM
kuruma's Avatar
We are not pulling the head. Why replace rings when compression numbers are great? I agree with retainers, Andy if I could I would go with some aftermarket Ti retainers and springs, if you have the money. I will do an inspection of the retainers when I have the valve cover off.
Old 10-29-2014, 12:24 PM
N777CK T's Avatar
Did you ever do this and did it fix the oil consumption problem?
Old 10-29-2014, 02:14 PM
chubbys2k's Avatar
Replace the keepers too. They are cheap. I was in the same situation as u and didnt want to pull off the head while replacing everything I could. At the end, I still smell some smoke
Old 10-30-2014, 08:00 AM
jkelley's Avatar
This thread is 6 years old. There is plenty of valve stem seal information out there.
Nametaek3n
05-07-2013 11:57 AM
Boofster
04-01-2011 11:22 AM
SWFLS2K
10-06-2006 08:13 PM
JohnChan
02-23-2004 01:14 PM
tboy911
05-23-2003 09:31 AM
Quick Reply: Changing Valve Stem Seals...
