Changing trans/diff fluid??????
So I need :
New washers and drain bolts
Honda MTF....2qts
Mobil 1 75w90 synth. gear oil....1qt
DOT 3 or 4 break fluid
HOW MUCH BREAK FLUID DO I NEED???
Is this all correct??? If so thankyou everyone for all the help!!!
Honda MTF....2qts
You don't really need new drain bolts.
Again, if you haven't you should look at xviper's how-too on the fluid changes you have in mind. He has provided the amounts and tools needed. Speaking of which..you might check into what tools you have. A couple of the sizes needed aren't espesially common and you would want to have them handy.
Also you will need some hose or a cheap pump to get the fluid into the diff and tranny.
