Changing Tranny oil.
Old 08-16-2004, 05:58 AM
  #21
Former Sponsor
Gernby's Avatar
Originally Posted by Road Rage,Aug 14 2004, 05:11 PM
I did my S2000 today with GM Synchcromesh FM, mostly on Gernby's recommendation (now the pressure's on, Gernby ).
I've already got my excuses ready if it doesn't work out for you.
Old 08-18-2004, 06:34 AM
  #22
buzilanga's Avatar
I'm about to change my clutch so I will change my tranny oil again. THis time i'll drain it while its hot.
Now instead of filling it via the fill hole. Can I get the exact amount I need of oil in a bucket and just full it where my shifter goes it? So i'll know I have exactly what honda specifies.
Old 08-18-2004, 07:01 AM
  #23
Former Sponsor
Gernby's Avatar
Sounds like a bad idea to me. You don't really know how much of the old oil will remain, and you don't really know what the "exact" amount of oil it needs. I also don't think it would be a wise move to fill through any other sealed openings.
Old 08-18-2004, 09:54 AM
  #24
buzilanga's Avatar
Well i don't see I can do any harm if I fill it form there cause itjust goes down.
HOnda specifies in the manual that 1.48L should be filled at fluid change.
So if I meassure that and fill it, don't think i will have a shortage.
Old 08-18-2004, 01:20 PM
  #25
xviper's Avatar
buzilanga, I truly hope you are joking about filling the tranny fluid from the shifter stick. You are going to dismantle the console, remove all the shifting hardware and then pour fluid down whatever hole you find? This is the goofiest way that I've heard anyone come up with. First, it's a lot of work. 2nd, we don't even know if there is a sufficient passageway for the fluid to follow to the tranny. 3rd, I don't even think that tranny fluid is supposed to go up there.
Lastly, Honda indicates how much fluid the tranny needs to fill it. Each individual case will be different depending upon how well the tranny drained. The "proper" prescribed way to fill the tranny (as stated by Honda) is to fill it till it comes out the fill hole with the car on level ground.
Old 08-18-2004, 02:40 PM
  #26
buzilanga's Avatar
I asked this question because, I once filled a few mustangs that way. 2nd i just wanted to know if its the same way, 3rd because i'm changing my clutch i have to deasemble everything, so i thought, why not try that way, but I came here first to ask advice. Now i'm sure I have to put my car leveled and fill it when i'm finish putting the clutch back in.
Thx for the tip xviper.
brock
01-13-2008 03:31 PM
mgebers
04-26-2007 11:16 AM
Jsmply
11-20-2006 11:21 AM
FMINUS
11-16-2006 10:13 AM
Dolemike
03-28-2005 12:24 PM
Quick Reply: Changing Tranny oil.
