changing spark plugs
ok i've just got a quick question so this should be an easy one for most everyone on here. I'm puttin in new spark plugs on the S and just wanted some guidance on how tight to put them in. I read on the denso website that you are supposed to turn then till they are about finger tight then to an quarter turn with the socket. does this sound about right or is there some other guide line I should go by?
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Unless there is a specific reason you are changing your plugs then I would say to stick with OEM plugs.
If you must change brands then at LEAST make sure the gap is OEM. .044 .045
Originally Posted by Fat Free,Jun 8 2006, 11:58 AM
I am sure there is a tq spec but the quter turn past finger tight is what I have always used on everything
Originally Posted by cdelena,Jun 8 2006, 12:59 PM
Use 18 - 20 lbs/ft. The old factory setting was not tight enough and was much of the problem that caused loose plugs and grenaded engines.
![iagree.gif](https://www.s2ki.com/forums/images/smilies/iagree.gif)
Originally Posted by SDS2K@9K,Jun 8 2006, 12:24 PM
yeah the ones i got come pre gapped at .044
BTW - 18 - 20 lb/ft is the CORRECT torque. If you want to play Russian Roulette, then go ahead and do the "finger tight" and 1/4 turn past.
![rolleyes.gif](https://www.s2ki.com/forums/images/smilies/rolleyes.gif)
![banghead.gif](https://www.s2ki.com/forums/images/smilies/banghead.gif)
15 lbs of torque IIRC
![dontdoit.gif](https://www.s2ki.com/forums/images/smilies/dontdoit.gif)
